Новости велоиндустрии
Re: Новости велоиндустрии
Сообщение 27 авг 2015, 07:56
Сообщение 27 авг 2015, 16:51
bluetooth гарнитура? :)
Сообщение 27 авг 2015, 17:18
ANT+
Сообщение 28 авг 2015, 07:03
перевертыш от RST
ждём на ашанбайках *okay*
Сообщение 29 авг 2015, 13:49
Сообщение 29 авг 2015, 16:00
А это с кого шкура? Змеинная?
Сообщение 29 авг 2015, 16:32
резиновое
Сообщение 29 авг 2015, 22:48
Шагающие велосипеды
http://www.elliptigo.com/
---------- Добавлено через 11 часов 46 минут 13 секунд -------------------------------------------------------
внутренняя проводка на стальном ситибайке - прогресс не остановить.
Сообщение 30 авг 2015, 21:23
Оффтоп: 2 xbz06ee
Ghost ROAMR
The ROAMR is a concept bike, a rolling test sled that Ghost can use to experiment with different ideas, including a Pinion gearbox drivetrain. Ghost place the 27.5” wheeled bike in what they call the “enduro overland” category, since its 160mm of travel is more than enough to deal with whatever obstacles may come its way, but features like a dynamo front hub that connects to a USB port below the stem's topcap for charging lights or other accessories hint that this isn't your run of the mill all-mountain rig.
Ghost have even developed frame and seat bags to go along with the ROAMR for bikepacking adventures deep into the burliest terrain around. One of the bike's designers will be piloting the ROAMR from Eurobike's location in Friedrichshafen, Germany, back to his home in Madrid, Spain, a journey that should provide plenty of opportunities to put it to the test. How much does the bike weigh? The exact amount wasn't available, but let's just say it's not exactly light.
A Pinion gearbox drivetrain drain means there's no rear derailleur to snag on rocks or get clogged with mud.
Take a closer look above the bike's stem and you'll see the location of a USB port that's powered by the dynamo front hub.
ну и самое интересное:
